Antenna coverage
Is it very easily possible to use a different antenna for the 5GHz radio? So for example a Dipole style antenna for 360 degree mesh coverage and connectivity to other antennas?
Or is it better to use the beam style antenna’s back to back to achieve the same coverage?
It’s very easy, you just need to get 5ghz omnidirectional antennas with the same RPSMA Male connector.
Thank you so much for coming back so quickly. So to confirm will we need y adapter to take both of the RPSMA connectors from the LR to an omni-directional antenna? Like this? https://www.amazon.co.uk/LIANGMEI-Qingqing-Splitter-Combiner-Pigtail/dp/B09KQHYFN1
Hi! No, you will need two omni-antennas, so just a cable adapter
Okay great thank you
