Default pirania handling do not support https request into mobile connected to client nodes
Hello there ,
I have installed latest v24.0 libremesh into my openwrt one router ,
default mesh network with internet sharing is working properly ,
then from libremesh page of gateway node into which internet is provided through ethernet , we configure and enabled the captive portal support and also created vouchers ,
when we connect AP of main gateway node , then it is opening the pirania captive portal as well as after applying voucher we can able to access internet into the mobile connected to AP of gateway.
but when we connect to AP of the client nodes connected to the gateway nodes , captive portal is opening but after applying voucher internet is not coming , only messaging in telegram and whatsapp is happaning but any website like youtube and facebook is not opening .
so our query is ,
  • is pirania handling the https request ?
  • and what is solution of this issue which is explained above , we tested multiple time by flashing multiple images but issue is same.
FYI,
Actually we have generated the ticket in libremesh github repo also , but they told that the maintainer is “Altermundi” so ask them also
issue link : default pirania handling do not support https request into mobile connected to client nodes · Issue #1206 · libremesh/lime-packages · GitHub
please provide your suggestion/solution for this issue .
Hello Librerouter team ,
request you to please provide your update for this issue
