I’m getting my LR set up for the first time. I updated to libremesh with the 1.4 image, and set up the router using limeapp. It was working fine serving the upstream internet connections on the WAN port to devices connected via wi-fi and the LAN port. Then I wanted to see what devices were connected to the LR, and couldn’t find a simple way of doing this via the web interface, so I installed luci. This seems to have broken the routing, as devices connecting to the LR now do not connect upstream. I removed luci, but the problem persists.
How do i reset the configuration to the default, and how do i easily see what devices are connected to the LR without having to ssh into the device? I guess i could reload the firmware image again, but that seems a bit drastic.
Even after rebooting the device route -n now says:
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.1.254 0.0.0.0 UG 0 0 0 eth0.1
0.0.0.0 192.168.1.254 0.0.0.0 UG 10 0 0 eth0.1
10.162.0.0 0.0.0.0 255.255.0.0 U 0 0 0 br-lan
10.162.0.0 0.0.0.0 255.255.0.0 U 0 0 0 anygw
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0.1
